The issue is, I want to remove all the articles from the Jasmin Demo Homepage. I cleaned the modules according to the tutorial (clean up demo homepage). Also cleared all the articles. But it has no affect.That does not work. See: skiriege.skiriegekonolfingen.ch.
Also have a look at the picture attached. That's strange to me.
In meantime the homepage does nit work anymore. Error 404. I removed the menu structure from Jasmin template and most of its articles. The strange thing is, the the preview of Jasmin and Cassiopeia end with Error 404.
To try to reinstall the J51_Jasmine_DemoInstaller.zip ends with:
JInstaller: :Install: Die Joomla!-XML-Installationsdatei konnte nicht gefunden werden.
(Joomla xml not found)
Das Joomla-Paket kann nicht wie andere Erweiterungen installiert werden. Hierfür muss die Joomla-Update-Komponente genutzt werden.
(Joomla Package cannot be installed as Extension. It must be installed as update)
How can I do this? Or must I remove everything and start from the scratch?
As the original homepage article was deleted, your home menu item was linking to an article that no longer existed hence the 404. I have linked your home menu item to your 'Aktuelles' link and the 404 is now resolved.
