1. joker911
  3. Friday, 17 July 2015
The ReCaptcha is not showing of in the template resonate latest version.
I tried new keys, i tried all settings of captcha in config file, in preferences file. Nothing ! The captcha is not there. Also there is a probleme with the different ways to show the contact .
May you can help me to fix this error ?
Thank you !
I send you the mail with credentials yesterday !
Is is ok for us to update your template to the latest version?
Before updating your template there is a couple of points worth noting.
1. All core template files will be replaced when you update your template. These are all the files located at ../templates/[YourTemplate]/ from the root of your Joomla installation. So if you have made any changes to these files, ensure to back up the template prior to updating.
2. No template style settings will be lost. All template style settings (Extensions -> Template Manager -> [TemplateStyle) are stored in the database and will not be effected by updating your template.
No changes done in /templates/[YourTemplate]/ you can install the latest version ! Thank you !
We have disabled jQuery in both instances of your slideshow module as jQuery is already loaded in Joomla 3.x. Duplicate instances of jQuery can cause issues with some elements. Your ReCaptcha should be now displaying correctly.
