1. pacoboss
  3. Monday, 14 May 2012
I am french and I bought the template affinity: http://demo.joomla51.com/0055/index.php?option=com_content&;view=article&id=19&Itemid=27
I have some difference when I deployed it:
- The menu top (hornav) don't show slowly
- The icon pdf, print and e-mail are different
- The detail of articles is different
Maybe is simplier if I give you my website link:
http://www.mariage.milipaco.fr/
Can you help me please?
Thanks in advance.
Hi pacoboss
Your hornav menu doesn't appear to be set up corretly, in particular adding moomenu to the menu modules Menu Tag ID (Extensions -> Module Manager -> [YourMenuModule].
For your icons my I suggest extracting the attached file in to your templates images folder (../templates/j51_affinity/images).
As our templates demo was created in Joomla 1.5 there will be some differences between it and how Joomla renders the details in Joomla 1.6 and above.
Thanks for your response.
I have tried to install moomenu but I don't find it.
Can you give me a link to download it (compatible with joomla 2.5)?
For the moment I have installed maximenu ck but it is too complex and the design is completely different.
For the icons, I have already the goood icons in ../templates/j51_affinity/images.
But I can see that the icons is pointed in ../media/system/images.
Where can I modify the link to pointed on the good folder?
Regards,
Hi pacoboss
For your moomenu there is no extra installation needed with your template. The moomenu script comes as part of the template. To implement the script you will need to add the text 'moomenu' to the 'Menu Tag ID' field in the menu modules parameters.
Unlike Joomla 1.5, Joomla 2.5 searches for the icons in ../images/system rather than ../images from the root of your template folder. If you wish you can simply create a folder called 'system' in your templates images folder and move the icons into that folder or extracted the system folder from the zip file in to your images folder.
For the moomenu is ok.
I found how to modify it.
In the "option of effect", I have checked "no" for the "fancy effect".
In the "option of styles", I have checked "no" for the "css of the theme"
Sorry if it is not exactly the same sentence. My menu is in french.
I don't have the "moomenu", maybe because I have the joomla 2.5.
But the problem with the top menu is solved (see my last post).
I have extracted the icons in "../images/system" but I have an other problem: All the icons are superimposed. How can I solve this problem?
Moreover, in the administrator menu I noticed that I miss the icon edit.png.
Can you give me this icon and icons you think I can use?
Thanks in advance.
I found how to modify the css but I don't know if it is clean.
I have added this in the template.css:
.print-icon { width:30px }
Now, I just need the icon edit.png.
Thanks!
Hi pacoboss
May I suggest sending temporary administration access to your Joomla installation to [email protected] (please reference this post) and we will set up your menu for you and have a look at your icons issue.
