1. JGrancha
  3. Friday, 21 February 2014
Hello!
A while ago I purchased a template and install it on joomla 2.5 but wanted to install in joomla 3.x gives me an error "JInstaller :: Install: Can not find XML setup file Joomla". Any solution?
Thanks!
Ensure you have unzipped your download before installing. For further details check out the following article.. http://www.joomla51.com/tutorials/item/why-do-i-get-a-cannot-find-joomla-xml-setup-file-error-when-installing-my-template
Yes, I'm sure that the first zip "j51-novation unzip first" is decompressed and I have installing de unziped file. I dont know what is the problem. I have a ticket of sale but i cant download again, the link is crahsed.
May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will install you template for you. For our reference please paste a link to this post in your email.
The installation is in local directory, I cant give you the access key. I send email with the ticket of sale. Check the link and reply me. Thanks
What is the filename of the file you are installing via your extensions manager? What version of Joomla are you using?
Filename: j51 - novation
Version of joomla: 3.2
Your template install file is called "j51_novation.zip" and is located in the "Joomla 3.x Install Files" folder of your download.
It's solved. I sent one mail to [email protected] and they have provided new link to download new template for version 3.x.
Thanks!
