On my template Calibra, i have a problem with the background i upload on Internet explorer.
When you down the cursor he is not stable
It s only with IE not with Mozilla or chrome, it s working perfectly with this 2
Can you help me please ?
Anne-Claire
Hi Anne-Claire
On what version of IE are you having this issue? Testing on both IE11 and Edge we are unable to replicate any issues.
I have internet explorer 11 too.
Try to go down with the mouse's scroll and you will see the problem
It s working well with the scroll itself but not with the mouse's scroll
Unfortunately we are still unable to replicate this issue. As a bit of a shot in the dark could you try adding the following to the Custom CSS field of your templates parameters...
#body_bg {
background: none;
body {
background-size: cover !important;
background: url(/images/bcenvers4.jpg) 50% 0% no-repeat fixed;
Hi Anne-Claire
We had forgotten to mention to also remove the set background image from the Style tab of your templates parameters as your image is now set to the body of your template. Doing so resolved the issue.
Yes you can now delete/disable the id and pass.
- # 10
