1. stefan49
  4. Thursday, 21 July 2022
i try to display the Slide Titel and Slide Caption, but it dont work ....
what do i wrong?
sorry, i forget to say: i use this module together with template cassiopeia, it works when i use Layla ...
that means, just working within templates from J51 ???
Ich habe das gleiche Problem...:(
hallo, ich konnte es teilweise lösen, mit folgendem CSS im Template:
.layerslideshow110 .info {
opacity: 50;
transition: opacity .5s;
Would you have a URL to an example of your issue?
I've got the same problem using this module in Joomla4, no title, no caption, only the blank little frames
Hi jotabe309
Just now I don't, my web site is off (in construction), I'll be back again for the case it does happen. Thank you for answering.
