1. paolo
  3. Tuesday, 13 January 2015
Hello, I have a problem while upgrading a website from joomla 2.5 to 3.3. This website uses j51 Choice template, and the RokSprocket module extension to showcase products.
Here's the website http://www.abrex-system.com and as you can see everything works fine with joomla 2.5 and the template I purchased 3 years ago.
On a local PC, I upgraded to joomla 3.3.6, and installed the 3.x version of the Choice template which I recently purchased. Unfortunately the RokSprocket module doesn't fit properly on the page; it should be a three column layout, but the last element of the row goes down to a new line, and the layout results unbalanced (see attached screenshot). The same thing happens if I set 4, 5 or 6 columns layout: the last element always goes down to a new line.
Also the buttons (default-title-date-random) used to choose products ordering, don't work, and even the top margin of the articles looks too small.
Intstead, if I set the default joomla template, the RokSprocket module works fine.
What can I do?
Hi Paolo
Would it be possible for us to have a look at a live example of the issue. It is very hard for us to troubleshoot an issue without been able to examine the effecting source and CSS.
I'll try to set up the site on a temp server.
Thanks!
