1. Ale
  4. Tuesday, 09 February 2016
I have a problems with Central template:
1.- How changue text color in sub menu? see my web: (section "productos";)
http://www.bercometal.cl/index.php/proyectos
2.- The sub menu is back of slideShow in the home main menu (image attached)
3.- In mobile devices the web is not centered. (image attached)
Regards,
Hi Ale
1. To amend try adding the following to the Custom CSS field of your templates parameters...
.hornav ul ul li a {
color: #ffffff;
2. Try also adding the following to the Custom CSS field of your templates parameters...
.hornavmenu-bottom {
z-index: 105;
3. May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
It work... I send you a mail.
Thank´s Ciaran.
Updating your slideshow module appears to have resolved the issue.
To answer your email question custom CSS can be applied to a single page by creating a template style to which you will add the custom CSS and assign to the menu items of your choice. For details on creating multiple template styles may I suggest the following article... http://www.joomla51.com/tutorials/item/creating-multiple-template-styles
Hi Ciaran thanks a lot!
In mobile devices the web is not centered. The problem is not solved with the updating my slideshow. (image attached) :(
