1. Concret
  3. Thursday, 07 August 2025
I can not edit articles!!! I have newer before had this problem with J51. How to solve? (Unable to find a user with the ID: 705)
- We need to solve this as sone as possible!
  1. http://www.amused.se
An option may be to create a new admin user and give it an ID of 705. Note you will be unable to edit the ID via the Joomla administration UI. Instead you will need to use a DB editor provided by your host (eg. phpmyadmin).
The issue certainly is unrelated to the template. Did you delete a user with ID 705? If yes, you might have to repair that directly in the database (i.e. using phpMyAdmin). Don't forget to backup before the activity!
