1. ziggy
  4. Friday, 28 June 2013
I have installed your Privilege template but in Autson slide show I'm not able to insert the alt tag for images.
If also I insert the title and description, the W3C Markup Validation Service returs the following error for each
image:
[color=#0044ff] Error Line 383, Column 84: required attribute "alt" not specified
…i/slide1.jpg" class="directionLeft" /></li><li><img src="/images/slide-grandi…
The attribute given above is required for an element that you've used, but you have omitted it. For instance, in most HTML and XHTML document types the "type" attribute is required on the "script" element and the "alt" attribute is required for the "img" element.
Typical values for type are type="text/css" for <style> and type="text/javascript" for <script>.[/color]
Is it possible to fix this?
Thankyou.
Best regards.
Claudio
