1. philscotland
  3. Tuesday, 18 July 2017
Hi :)
I am using the Pianoforte template and my logo width is 800px. If the browser window is resized below 800px, the responsive menu kicks in. I don't want to switch off the responisve menu,but I would like it to only kick in at around say 300px, regardless of my logo width.
Can you tell me how to do that please?
Thanks.
May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will make this amendment for you. For our reference please paste a link to this post in your email.
Sorry, I don't feel comfortable emailing login details. Surely it is possible without doing that.
In your templates responsive.css (../templates/j51_pianoforte/css/responsive.css) cut the following...
/* Hide default hornav menu */
#hornav, .hornavmenu {display:none !important;}
/* Show mobile hornav menu */
.hornavmenumobile {display:inline; z-index: 99; }
And paste after the following...
Hi Ciarán,
What is happening now is, when the browser is resized to between around 940px wide and 1060px wide, the screen jumps back to the responsive menu. It is just inbetween those values though - above and below them the menu is the unresposive menu. My logo width is 900px if that makes a difference?
Thanks.
Excellent, thanks for that :)
I do have the same behavior in my pianoforte template, using two languages.
German:http://www.mba-uni.de/de-de/ (mobile menu works)
English: http://www.mba-uni.de/en-us/ (mobile menu does not work)
Should I start a new topic or is it fine here?
Thanks!
Hi Ciarán,
i sent you an email some minutes ago. Thanks in advance for your help.
Christian
I have created a new template style for you for your English language, in which I have select the English menus/language. This appears to have resolved the issue?
Hi Ciarán,
thank you very much for your support. Unfortunately no menu appears, neither in full screen nor in mobile view. I tried to change module position, template and menu assignment. It did not help.
Of course I can offer you my help, so we can try to fix the problem together.
Best
Christian
I did some research and found/did the following:
1) The new (en-us) template seems not to work. I changed some basic colors, but it is still the same like the (de-de) template.
2) I turned off caching, as long as we are solving the problem
One additional information. switching to english and using module positions for the mobile menu leads to the following source code problem: the div "hornavmenumobile" is empty.
<div class="hornavmenumobile">
<div id ="nav">
</div>
</div>
Checking your site source there appears to be a couple of JS conflicts. Could you try disabling your cookie warning extension and see if this effects the issue?
yes, this is the solution. I deactivated cookiehint and now the mobile menu also works fine. thanks a lot.
do you have an idea about a compatible cookie hint plugin?
Best
Christian
Hi Christian
Most extensions should have no issues. A common issue is an extension will attempt to load its own version of jQuery which usually results in such issues. As long as your extension leave loading jQuery to Joomla then you should have no issue.
