1. cagnoli
  3. Tuesday, 10 January 2023
I am trying to put paypal buttons into my content. If I use the Verona template it works fine, while if I try Chloe or Carmen the buttons do not show, but in Chrome the links are there and work even if you can't see them.
Can you help me in fixxing this problem please?
.visible {
opacity: 1 !important;
the solution suggested simply works! :D
Thankyou for your help.
Same problem with the Carmen template, but this workaround is great for solving this kind of issue.
Andrea
I am using the 'Custom Html Advanced' module, and added your code in the 'CSS style overrides' section and it is working.
Thankyou for your reply.
https://www.voloavela.it/rivista-volo-a-vela/come-abbonarsi
on the left column you can see the title of the module with buttons not showing. This is Chloe. If I put the Verona template on this page, it starts working. Do you need credentials?
