1. ziggy
  4. Tuesday, 18 December 2012
First of all, thanks for a good template.
I would be very grateful if someone could help with this issue.
I have some articles under category blog with navigation on "show" both in the article options and in the category blog options. But the navigation doesn't show.
When I change to other templates (beez or atomic) it does show.
At the moment the site is off-line.
Any ideas?
Hi Javier
May I suggest that once you have your site online to send temporary administration access to your Joomla installation to [email protected] and we will examine this for you.
If this issue is unique to this template try removing the templates com_content (../template/j51_oxygen/html/com_content) folder and pagination.php (../template/j51_oxygen/html/pagination.php) if present.
Hi Ciarán.
I have removed com_content folder and pagination.php and, the pagination is showing now! Problem solved.
Thank you!
Javier
