1. muetzli
  3. Wednesday, 11 April 2012
Hi there
We have bought the "arabic" template of Joomla51. Unfortunately special characters like äöü (Umlauts) are not showing on our page, despite UTF-8.
The language files are GB-en. Do we have to install other language files? Are there any other than GB-en available at all?
The special characters are showing in other installed modules (like yoo_recepie etc.).
Thank you in advance for your help.
Tanja
Try adding the following directly after defined('_JEXEC') or die; in the head of your templates index.php (../templates/j51_arabica/index.php)
header("Content-Type: text/html; charset=UTF-8", true);
Hi Ciarán
Thank you very much for your quick help. Unfortunately that didn't help.
Have you got any other ideas?
Tanja
Hi Tanja
May I suggest sending us temporary administration access to your Joomla installation to [email protected] so we can examine the issue further.
