I have a problem with the Nocturne Template, when I open the gallery (I have the 2J Gallery, Lightbox) then the font in the menu is out of focus.
Thanks! You can tested here
Thanks for the replay, the font is now in Focus but it is still not good. No hoover effect and no hoover color. The font color is gray and not black. This happens only on the Gallery site (2JGallery). I would be very grateful for further suggestions.
There appears to be a clash with your gallery extension and the templates dropdown menu. I tried a fewer 'shot in the dark' type fixes but all allowed the dropdown to function but your gallery stopped. As I am not familiar with this extension it is very difficult to say what may be causing this. The best I could do was to style your dropdown so it looks exactly as it does on your other pages however the animated effect will no longer function on this page.
Thanks.
I tried before 4 different gallery extensions and everything was the same. I think that has to do with the template.
I will continue to try to solve the problem. Please write me if you find something or you have a new idea.
