Hi thanks for the reply. I was successfully able to create a module and put it in an article using the tutorial you provided. Is it possible to include the {loadposition myposition} in the descriptor text of the Filler module?
Rather than using the ImageLinkHover module used in the 'filler' modules used on the demo, try using Joomlas 'Custom HTML' module (Extensions -> Module Manager -> New -> Custom HTML). You can then place the loadposition tag along with your text in the 'Custom Output' tab of this module. Note that you may need to find an alternative slideshow module to use, as the J51_Slideshow does not fully support multiple instances of itself on the same page (http://extensions.joomla.org/extensions/photos-a-images/slideshow).
