1. Apexsys
  3. Tuesday, 07 May 2013
Hello, first off all nice work Stunning Template :whistle:
I Have a Question about Some modules at the Frondend.
How can i Fix the "style Width & hight" of the top-3a Filler1-4 Boxses and ther Buttons ?
If Text is longer or shorter as it is in the Demo.
I only found the "Enable Manual Widths" Parameter in Template Settings but it kills the Complete style :/
http://shutterpix.de/images/DEMO/modules1.JPG
Hi R
Your best option would be to set the height of our modules using CSS. Would you have a URL to an example of your modules?
http://www.shutterpix.de i have no css knowledge ... :blush:
Try adding the following to the Custom CSS field of your templates parameters...
[code type=css].module_style-box p, .style-box p {
height: 120px;
}[/code]
Thank you!
Works very well, and is there a code for the buttons under the Boxes there size also depents on how many text is in it.
If the text is lager then the button it will extend and if text is shorter the box will keep the dedault style ? ÄI have no idea :blush:
If you have no option to reduce the length of your button text, an alternative is to reduce the number of modules you have inline (3 rather than 4). This will allow you to increase the width of your modules and therefore giving you more space.
Hello i have installed Admiror Gallery.
It makes a double lightbox popup for images.
I think its a problem with the buildin lightbox.
http://shutterpix.de/index.php/webz/gal
I found out that the error comes form this
{AG rootFolder="/images/sampledata/" thumbWidth="200" thumbHeight="120" thumbAutoSize="none" arrange="priority" backgroundColor="ffffff" foregroundColor="808080" highliteColor="fea804" frame_width="500" frame_height="300" newImageTag="1" newImageTag_days="7" paginUse="0" paginImagesPerGallery="10" albumUse="1" showSignature="0" plainTextCaptions="0" ignoreError="1" ignoreAllError="0" template="classic" popupEngine="slimbox"}MyPic{/AG}
it collide with the build in slimbox ?
how can i slove this without changing the AG gallery gallery mode, fancybox e.g. fix the error.
It appears the slimbox script is been loaded twice. Once by your Admiror gallery and again by the thumbs gallery module. One solution is to avoid both galleries to be on the same page however that may not be suitable. If you have an alternative lightbox option to slimbox in your galleries parameters should also resolve the problem.
Failing that may I suggest sending FTP access to your thumbs gallery module folder (../modules/mod_j51thumbsgallery) and I will see is there another solution. Details can be sent to [email protected]. Please paste a link to this post in your email for our reference.
