MENU
  1. Torbjörn
  3. Friday, 03 January 2025
No J51-module extensions were installed with Emani template installation.
Should I try to download the template again from J51, and re-install it to Joomla Extensions?
Or is there another solution ?
Joomla 5.2.2
Emani v.2.0.0
you should install the extensions separately from the template. they are in the same downloaded map as the template
Thanks - just one question :
Did I download the wrong file ?
All the folders and files are for j4 (see below).
Maybe I downloaded the old J4 template......
j51_emani_j4.zip
mod_j51calltoaction_j4.zip
mod_j51icons_j4.zip
mod_j51imagehover_j4.zip
mod_j51inlineicons_j4.zip
mod_j51layerslideshow_j4.zip
mod_j51news_j4.zip
mod_j51numbers_j4.zip
mod_j51progress_j4.zip
mod_j51rotate_j4.zip
mod_j51testimonials_j4.zip
mod_j51thumbsgallery_j4.zip
you should install j51_emani_j4.zip into your joomla installation first and then the mods you need
