1. salinger
  4. Tuesday, 09 June 2020
I am using Bianca Template here https://www.johnny-matrix.com/index.php
My customer wants to look it like this website https://www.btstrm.com , so no header, video only. is that possible with this template and how?
thank you, Marion
Hi Marion
To hide the header of your template you can add the following to the Custom CSS field of your template settings...
#container_header {
display: none;
Hi Ciaran, thank you but thats not really working... 1st there is still a black frame on top of the video. 2nd the menu is gone. is there another solution?
thank you marion
Hi Marion
To hide specific elements of the page you can try the following CSS instead (edit to taste)...
.header_main {
#logo {
display: none;
#socialmedia {
display: none;
Thank you Ciaran, but that's still not the desired result... still a black frame on top of the video. it should look like this
maybe with an other template?
Hi Marion
Sorry to say w do not currently have a template exactly matching your example which is quite unique in its design.
To remove the background of your header and to place the showcase position behind the header you can add the following to the Custom CSS field of your template settings...
#container_header {
position: absolute;
top: 0;
.header_main {
box-shadow: none;
we are getting there :-) but still not exactly perfect :-) please look at the screenshot, thank you.
We are unable to replicate your screenshot (Firefox and Chrome). Have you since resolved this?
