1. chrish
  3. Wednesday, 01 December 2021
Hello !
Since I installed Nina (the last update : 11/29), I encounter a few issues with the modules, now there are the ones I noticed until now :
- Layerslideshow : there is a problem with the min-height class... It's very small, and you can't change it.
- Layerslideshow : it stays on the first photo
- Thumbsgallery : Doesn't work at all. I have the error message : file not found... and stays locked.
Here are the first issues I observed. I hope there are no other.
By the way, my site works with Joomla 4.04
Have a good day ! :)
Christine
Hi Christine
Would you have a URL to an example of these issues? Have you the latest download of the template installed?
Thank you for answering.
This is a website still underconstruction : http://ihcgakt.cluster031.hosting.ovh.net/ValN/
The last update running is from 29/11. If you ask the question, I guess there has been another one since ?
I'm going to check and install it.
Do you need an administrator access anyway ?
Hi Christine
The last update was on the 29th which should at least resolve your last issue.
Yes. May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
