1. Natalja
  3. Wednesday, 30 January 2013
Hi!
I want to make such on the page, prompt as it to make? (look an investment) What module to use and how to make the button.
I want that the button was the link to the contact form.
Thanks.
You can edit your button by adding the following CSS to the Custom CSS field of your templates parameters which you can edit to your own taste..
[code type=css].j51-button a {
background-color: #64636b;
background-image: -moz-linear-gradient(top,#64636b,#46454b);
background-image: -webkit-gradient(linear,0 0,0 100%,from(#64636b),to(#46454b));
background-image: -webkit-linear-gradient(top,#64636b,#46454b);
background-image: -o-linear-gradient(top,#64636b,#46454b);
background-image: linear-gradient(to bottom,#64636b,#46454b);
}[/code]
Where #64636b is your gradient top colour and #46454b is your gradient bottom colour.
whether and it is possible to make the button is a little lighter? :huh:
Thanks for quick answer :woohoo:
It functions!
To recreate this module first set your Joomla editor to CodeMirror (Site -> Global Configuration). Create a Custom HTML module (Extensions -> Module Manager -> New -> Custom HTML) and add the following code..
<p class="j51-button" style="float:right;">
<a target="_blank" href="http://www.joomla51.com/joomla-templates/j51-clarity">Purchase Now</a>
</p>
Where http://www.joomla51.com/joomla-templates/j51-clarit is your button URL and 'Purchase Now' is your button text. Edit to taste.
