1. ravibhat
  3. Monday, 23 December 2013
i am using your Privilege template
i need different images on internal pages header how can i change ?
and not in slide show i want only one image there is this possible to take ??
Would you have a URL to an example of the header area you wish to change on different pages of your site?
One option is to duplicate your single image and set the transition to 'fade' in your slideshows parameters. Your 2 images will then appear as a single static image.
pl check website http://sumanvillas.in/
in this website u see every page have new header so i need to change images of internal pages header of my website http://symacconsulting.com/ how can i do that there is no options ??
pl suggest
A number of instances of your slideshow can be created by navigating to Extensions -> Module Manager -> New -> J51_Slideshow. You can set each instance of your slideshow to the menu items of your choice via the 'Menu Assignment' tab within your modules parameters,
