1. SllimKev
  3. Tuesday, 16 December 2014
Hey Joomla51,
Installed the J51_ThumbsGallery to the Habitat template today. Thumbs loaded fine. However, when I click on a thumb to view the gallery the only navigation option shown is the "Close X" button in the bottom right corner. "Next" and "Prev" are not showing so the only way to view the gallery is one image at a time.
I've uninstalled Simple Image Gallery Pro component. I've unpublished the J51_GridGallery and J51_SlideshowModule... still no luck. Tried in Chrome, Firefox and IE...same result.
Here's the page http://www.cedargatestudio.com/island-533/index.php/eco-cabin-eco-loft
Any ideas?
Cheers, Kevin
Hi Kevin
Thank you Kevin
In your modules mod_j51thumbsgallery.php (../modules/mod_j51thumbsgallery/mod_j51thumbsgallery.php), could you try replacing the following (line 45)...
<a class="j51Box" style="margin:<?php echo $margin;?>px;" rel="lightbox" href="/<?php echo $item['image'] ?>">
With..
<a class="j51Box" style="margin:<?php echo $margin;?>px;" rel="lightbox-thumbs" href="/<?php echo $item['image'] ?>">
Hi Ciarán,
That seems to have done the trick... Gallery working fine. Thanks so much for your quick help on this.
Joomla51 templates are the best! Top class.
Kevin
  3. # 3
That workaround worked also for me, but I do not like to manually edit my extensions, because edits can be overwritten in future upgrades.
Do you plan to commit that fix in an official released version of J51_ThumbsGallery?
Thank you!
  3. # 4
Indeed.
We will add this fix to the thumbsgallery on the next round of template updates.
For the time been here is the module install file with the fix applied...
https://dl.dropboxusercontent.com/u/69136519/mod_j51thumbsgallery.zip
Thank you for bringing this issue back to our attention.
  3. # 5
