1. WEBcatch
  3. Friday, 30 September 2016
Hello, I have been searching and trying stuff, but I can't find a way to adjust some heights in the template.
I would like to have the bloks and grey line on the page go upwards, the wrapper and the header are too high.
Where can I change that?
http://www.wijkbladdelindenberg.nl
Presuming I understand you correctly try reducing the vertical margin in your J51 Carousel module (currently set to 140px). This will reduce the height of your showcase area.
That works, but now the grey stripe disappears. It's not just the carousel height, I want the text also to come up higher.
I am not sure if I understand you correctly. Could you detail for me which text you wish to move up if not the carousel text?
I hope that the attachments help.
The blocks should be as in attachment 1, but with the intro text to come up higher, closer to the blocks.
When I change the Carrousel height, the grey line (attachment 2) dissapears.
So it would be nice to have the blocks go up together with the intro text, but without the grey line dissapearing.
Thank you.
To amend try adding the following to the Custom CSS field of your templates parameters which will both move up your top-1 modules and reduce the space above your article....
.maincontent {
padding-top: 30px;
.top-1 .gridgallery {
margin-top: -180px;
Nothing happens :(
Done!
The Custom CSS appears to be working correctly. I have reducing the vertical spacing of your carousel module to bring the appearance close to your first screenshot.
Thank you!
The text and the blocks are in the right place, but the grey line has gone :(
Is it possible to have that back?
#container_top1_modules {
border-top: 10px solid #888;
Yes, my grey line is back!
Nearly perfect!
I would like one last change ... the white space as seen in the printscreen is quite big, can I reduce that?
In other words, the space between the grey and orange line, can that be smaller without changing anything else? Because the top is perfect now!
Presuming I understand you correctly, this space appears to be determined by the content in your article and top-1 module area. Maybe reduce the height of the images in your GridGallery module?
Oké, so it is not possible to change the height of the light-grey in the template? If not, I will change the pictures, or change nothing else :)
The height is determined by its content. The only alternative is to reduce the padding around the content.
