1. PattiHorse
  4. Friday, 29 May 2020
Is there a way to have the module I have in header-1 position "push" down the sidebar module below it in CSS instead of overlapping on top of it? Thank you for any help.
Would you have a URL to an example of your header-1 module?
The issue is that the header-1 modules are in a completely different wrapper div than the side column modules so there is no way one can affect the other. The only solution that comes to mind is to duplicate your header-1 modules, placing the duplicates in the side column module positions. Use the menu assignment tab of the module to assign them to the appropriate menu items.
I will give that a try and let you know how it goes. Thank you very much!
Just sent you an email.
