1. [email protected]
  3. Wednesday, 04 January 2017
I'm using the Nadia Template. I just wondering if it's possible to re-size the logo frame/background.
Currently I'll see always a frame/background. My logo size is e.g. 190x84 . See attached sample - the frame / background (marked red) should not appear. The logo should use the whole logo area without any frame.
Thank in advance.
Kind regards
Werner
Hi Werner
Would you have a URL to an example of your logo?
Hi Ciarán,
thanks for the very fast response. See link below.
It's the black logo in the middle of the dark gray background.
Werner
  1. http://www.airservice.flywinx.de/
Thank you Werner
.logo {
padding: 0;
Hello Ciarán,
thanks for your help. Works fine.
Werner
Great. Thank you for the update.
Is there a way to have the logo bk the same as the header bk colour and opacity?
