1. omartin
  3. Monday, 14 May 2012
I have the next error when I install the mountain pine template.
( ! ) Notice: Undefined property: JDocumentHTML::$_name in C:\wamp\www\fina\libraries\joomla\plugin\plugin.php on line 103
Call Stack
# Time Memory Function Location
1 0.0009 699984 {main}( ) ..\index.php:0
2 0.3871 14563032 JSite->render( ) ..\index.php:48
3 0.3874 14563888 JDocumentHTML->parse( ) ..\application.php:260
4 0.3874 14563888 JDocumentHTML->_fetchTemplate( ) ..\html.php:414
5 0.3878 14564392 JDocumentHTML->_loadTemplate( ) ..\html.php:591
6 0.3898 14772304 require( 'C:\wamp\www\fina\templates\j51_mountainpine\index.php' ) ..\html.php:531
7 0.3898 14772664 JPlugin->loadLanguage( ) ..\index.php:3
( ! ) Notice: Undefined property: JDocumentHTML::$_name in C:\wamp\www\fina\libraries\joomla\plugin\plugin.php on line 105
Call Stack
( ! ) Notice: Undefined variable: siteName in C:\wamp\www\fina\templates\j51_mountainpine\index.php on line 93
Call Stack
#TimeMemoryFunctionLocation 10.0009699984{main}( )..\index.php:0 20.387114563032JSite->render( )..\index.php:48 30.387414563888JDocumentHTML->parse( )..\application.php:260 40.387414563888JDocumentHTML->_fetchTemplate( )..\html.php:414 50.387814564392JDocumentHTML->_loadTemplate( )..\html.php:591 60.389814772304require( 'C:\wamp\www\fina\templates\j51_mountainpine\index.php' )..\html.php:531 ">
( ! ) Notice: Undefined variable: siteName in C:\wamp\www\fina\templates\j51_mountainpine\index.php on line 94
My version of Joomla is 2.5.4.
I have a Wamp Server 2.2.
I try to install this in Joomla 1.5 and work perfectly.
Advance Thanks for any answer!
Hi omartin
May I suggest replacing the following in the head of your templates index.php (../templates/j51_mountainpine/index.php)
<?php
defined('_JEXEC') or die;
JPlugin::loadLanguage( 'tpl_SG1' );
JHTML::_('behavior.mootools');
define( 'Jmasterframework', dirname(__FILE__) );
require( Jmasterframework.DS."config.php");
$path = $this->baseurl.'/templates/'.$this->template;
$app = JFactory::getApplication();
$app->getCfg('sitename');
$sidecol_width = $this->params->get('sidecol_width');
$col_pos = $this->params->get('col_pos');
$templateparams = $app->getTemplate(true)->params;
With
<?php
$siteName = $this->params->get('siteName');
Thank you!!
