I add the moomenu to Menu Tag ID of my hornav menu. But it's not working. My browsers give me following error:
Uncaught ReferenceError: Class is not defined (dropdown.js)
There appears to be an issue with one of your extensions causing a conflict with other scripts on your template. May I suggest uninstalling any extensions/plugins you are not using and see if this resolves the issue.
