1. patrickbmccabe
  4. Thursday, 05 December 2019
using Jasmine,
I want to use 2 Image hover modules side by side, and they should fill the row.... and most importantly. be the same height even when the images of exactly the same height they rarely stay the same height.
http://d1189658-117041.blacknighthosting.com/2020Cape/index.php/residential-projects
I am trying to achieve this
http://www.newwave.co.uk/project_category/selected-build-projects/
Any ideas?
Hi Patrick
Firstly enable the Remove Container Padding option in the Module Widths tab of your template settings for each of these module positions. We should then be able to give you the required CSS.
Thank you Ciaran,
I have enabled the Remove Container Padding on all modules from top1 down to base 2. Thanks again
Strangely the padding still appears to be present. May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
