1. evensenj
  3. Saturday, 16 May 2015
I have read how to change the label in the js file. It works fine, but I have a multi-language site and need the label to change according to the language file in use.
Do I need to create a separate template for each language? or is there a way to set the label as language variable and add it to my language file?
Thank you.
Presuming you are using one of our more recent template releases, firstly you will need to remove the following from your templates scripts.js (../templates/[YourTemplate]/js/scripts.js)...
// Slicknav - Mobile Menu
$('.hornavmenu .hornav').slicknav();
You can then call the mobile menu script from within your templates parameters via the 'Custom Code -> Head Custom Code' and set the label...
<script>
jQuery(function(){
jQuery('.hornavmenu .hornav').slicknav({label: 'MENU'});
</script>
You can create a new template style for each of your languages, editing MENU to your own taste.
Thank you! I am using the Journal template and there is no script.js file. Where would I look for this code?
If no scripts.js exists then the same code can be found in your templates scripts.php (../templates/[YourTemplate]/php/scripts.php).
Well, I'm finally back to working on this again... I got this working with the Lifestyle template. But the Journal template does not work. I commented out the lines in the scripts.php that matched the custom code you gave me to insert into the Head Custom Code on the template. The menu disappeared as expected when I commented out the code, but it does not appear when I add it to the Head Custom Code.
Any thoughts?
