1. pigos
  4. Sunday, 01 February 2015
Hi Ciaràn,
I'm working on this site:
http://www.erumpere.eu/wip/
based on Joomla 3 and J51 Classic. The site is multi language
I am not able to change background and text color on mobile menu, what I got is attach1
Menu setup in Classic is here:
the menu is assigned to hornav-mobile position and the advance dconfiguration is here:
I try to add this code in the template css:
#hornav-mobile {
background-color: #000000;
color: #ffffff;
the full template css is attached.
Please give me some hint. If you think that other J51 template is best suited for mobile, give me an indication and I will buy it.
Many thanks and regards
do you have firebug installed?
I had a similar issue and i used firebug and firefox to change it in to the desired colour.
I minimized the size of the window first .
I had to edit the files though i dont know if there is another method of doing it.
..............just in case you are new to websites like me.
Thanks magsmag, it works like you say.
The css parameters are:
.slicknav_menu .slicknav_nav a {
color: #ffffff;
.slicknav_menu .slicknav_btn {
color: #ffffff;
