When using the metropolis template in responsive mode on a mobile device I have a few issues I'm hoping are simple and you can help me with please:
1) There no icon or indicator that shows where to tap the screen to select the menu when in responsible view (this is very common on many other responsive/mobile templates i've used) . Is it possible to add this? The responsive menu looks like a breadcrumb view, as it has moved from the Hornav position, and it isn't obvious this is the actual menu now.
2) Why does the position where you tap to enable the menu selection move from the HORNAV position (above the logo) to just above the Breadcrumbs position (below the logo) - is it possible to keep the menu location (with addition of an icon) in the HORNAV position so it is consistent for users who visit both the full site and the mobile site?
3) The responsive menu text (below the logo) is not center aligned within the menu border area and thus the bottom of the text in that field is being cut off. Is there a way this can be addressed?
4) the standard Joomla contact form does not fit properly within the responsive view. The contact form fields are indented to the right and thus are cut-off by the metropolis template boarder.
5) the email and phone number fields in responsive view are not beside the icons, they are below the icons on the next line (in standard view the alignment is incorrect in this area as well).
I'm running Joomla 3.2.3.
thanks very much
