1. KChev
  4. Wednesday, 03 December 2014
I am having a similar issue as the person using Lifestyle who posted on this forum a week ago (#13501).
I made a site earlier this year with Metropolis and placed a slideshow within the content using the loadposition method. Today the client rang and said that page is not loading at all, just showing a blank page. When I removed the loadposition command the page loaded (but without the slideshow of course). The only change I had made in recent weeks was to update to Joomla 3.3.6.
I posted my problem on the joomla.org forum and was advised to put back in the loadposition command and then upgrade the error reporting in global configuration to Maximum, then reload the page. I got this error message:
Fatal error: Class 'JFile' not found in /home/eq98972/html/modules/mod_j51slideshow/helper.php on line 25
I just now had a reply from the joomla forum person who said I should either add this before line 25 of your slideshow module
jimport('joomla.filesystem.file');
"or contact the developer". So I'll wait for your reply before fiddling around with the code.
Kim
Hi Kim
The suggested code should be already in the head of your modules helper.php (line 10) ?
Yes, you are right, that code is already at line 10. That guy who replied on the joomla.org forum got pretty snippy when I told him that, claiming he knows he's right. Anyway, I tested out load position command on a site I'm currently working on using Journal and I had no problem. I checked the helper.php file for the Metropolis and Journal slideshow modules and they are identical. So I'm at a loss here. I'm going to tinker around some more, but if I haven't solved it by Monday could I trouble you to go in using temp admin access and take a look?
Sure. Forward your access details to [email protected] and we will take a look for you. Ensure to paste a link to this post in your email for our reference.
