1. bariwebinfotecnica
  3. Sunday, 01 January 2023
I'm using the Ensley template in a J4/Virtuemart project.
I noticed that every message appearing can't be closed with the usual X at the right-top corner. The close-button is uneffective.
Please try adding one product to the cart and the confirm message will remain visible.
Thanks in advance for your support.
Maurizio
  1. https://demoprogetto.it/progetti/genifarm/20221205/store
Hi Maurizio
As this issue is with an element within the VirtueMart component, have you tried posting your query to the Virtuemart support forum?
thanks for replying me.
Actually I didn't notice the messages as connected with Virtuemart.
No similar topic in the VM Forum at the moment: I just posted it.
Maurizio
Hello CIaran,
I posted the question in the VM forum, receiving th suggestion to update the VM release.
Since nothing changed after updating, I just tried associating the cart page to Cassiopeia template.
The messages are correctly closed by the top-right X sign.
So I think that the problem is inside the Ensley template and it's probably not the only one I'm running into, since the autoplay of a J51_News module doesn't work either (and I had to use it static, without autoplay)
Any suggestions?
Thanks in advance
Maurizio
Hi Maurizio
