1. bollie58
  3. Tuesday, 17 April 2012
I have 2 problems with the menu in the Choice template:
1. Please look at: http://www.deconcurrentieissprakeloos.nl/index.php/en/
Then choose the products menu. After that there are 2 sub-menu's. At each choice there are new menu items and after thas again new menu's. The first dropdown works ok. The second and third level dropdowns mostly dissapear when i go with the mouse to the next. It's hard to get to the last menu item.
2. When you mouse over a menu, the submenu's are showing. When you click on a menu item with a submenu attached, you wil get to a artikel page. I need only to display the submenu's when someone clicks on the mainmenu item.
Hi bollie58
I dont see the Menu Tag ID in your menus source.
If you wish you can send temporary administration access details to [email protected] and we will set up your menu for you.
I did that for all the menu's, all languages.
To set the Menu Tag ID (J2.5) navigate to Extensions -> Module Manager -> [YourMenu] -> Advanced Options -> Menu Tag ID and insert moomenu.
Thanks for the reply. The 2e solution works fin. Problem solved.
The 1e solution seems not to work.
I added Moomenu to all the id's on all languages. But still the same problem
Something i did wrong?
Hi bollie58
1. Your menu module does not appear to be set up correctly... in particular setting the Menu Tag ID to moomenu within your menu modules parameters.
2. To set up a non linked menu items uses Joomlas default separator menu item.
