1. ntsnet
  4. Monday, 06 January 2020
Hi, The main menu on the site and logo are in the standard template menu position and not as a module in the 'hornav'. There seems to be a problem with the display of menu items (and logo) in Safari browser (version 13.0.4). On hover, all of the items disappear except the one under the cursor.
Scrolling down so that the menu shrinks in size, then it isn't a problem. Puzzled! I checked it with Chrome and that doesn't have this problem.
Site is somersetcaninemassage.com
Any clues please??
Thanks, Paul
  1. http://somersetcaninemassage.com
Are you having the same issue with the template demo (https://www.joomla51.com/demo/0145/)?
Yes! I didn't use to have a problem with this, but possibly the latest version of Safari (13.0.4) is now giving the problem?
I assume that a smaller percentage of people will be using Safari compared to other browsers, but it is still a problem - I guess it's in the code somewhere!
Thanks,
Paul
Hi Paul
We have made a few changes to the template demo. Does this issue still exist (homepage only)... https://www.joomla51.com/demo/0145/
OK, some success ... The menu items only disappear for part of the time. On first opening the home page I can select the menu and get the sub-menus up as well, but then if I move the cursor along and over one of the menu items they will all vanish! Logo stays there all the time thoug.
Regards,
Paul
Hi Paul
Thank you for your patience.
.hornav, .hornavmenu,
.vegas-wrapper, .header_row {
    z-index: 2080;
Was out for a couple of days.... Have tried the solution and that seems to have worked.
Once again many thanks for your quick response,
Paul
Great... thank you for the update!
