1. mcardenas
  3. Friday, 04 May 2012
Hi:
We purchase J51 - Revelation, and it is having issue with the submenu. Whenever a click on the first level menu, it shows the submenu but won't let me select the submenu.
Would you please assist us:
Here is the link.
Click Here.
we want something at least working as the following website:
Click Here.
Thanks a lot for your help.
Mibsam
Hi Mibsam
It appears your hornav menu is not set up correctly in particular adding moomenu to the Menu Tag ID field in the menu modules parameters (Extensions -> Module Manager -> [YourMenuModule].
I went in there but I do not see anything to change. I did not move anything in there? what do you recommend doing?
PS:
[attachment]Screen Shot 2012-05-04 at 1.27.11 PM.png[/attachment]
I attached screenshots
Add moomenu to the Menu Tag ID .. under Advanced Options
Now the menu is having more issues because it won't let me select anything. any suggestion?
Hi mcardenas
You appear to be using a version of the template which is compatible with Joomla 1.6 & 1.7 only. If you could forward us your purchasing PO number to [email protected] and we will send you the latest version of the template which is 2.5 compatible.
thanks so much for you help! Really fast support
