I am using the standard home page layout with the menu in the middle of the page (https://hyvacinc.com) for the template Boss. I need to add an additional menu across the top in the header position. Should I create a new module position in the header? If so how do I code it to be the same as the main menu. Or should I just try to find a plugin to accomplish that?
Thanks for your guidance.
