1. pat02
  4. Saturday, 25 November 2017
I did enter a slogan text, but it is not visible in the frontend. I even did check the source code, but no slogan text there.
How can I add a slogan text?
Thank you very much!
Template: Maya
Joomla: 3.8.2
Patrick
Hi Patrick
By default the slogan text will only appear if the Logo image option is disabled. Is this the case that you want the slogan to appear below a logo image?
Hello Ciarán
Yes, I need the slogan text below the logo.
Thanks!
Patrick
Hi Patrick
May I suggest sending temporary administration access to your Joomla installation to [email protected] and we will make this amendment for you. For our reference please paste a link to this post in your email.
Hi Ciarán
I have the website on localhost, not online yet.
Anyway, hacking core files of the template will result in losing the changes on next template update.
Nevertheless, I have done so (please see attached file).
Maybe you want review my changes and add them to the Maya template? :)
Thank you very much.
Patrick
Hi Patrick
Thank you for sharing your solution. We have updated our Maya template to allow the display of both a logo image and slogan text as suggested.
Hello Ciarán
I updated the template and did testing. Works fine!
Thank you very much for adding this! :-)
Patrick
