1. omalik
  3. Tuesday, 04 March 2014
Hello i have bay the template RENOVATE from you. Do you have a Manual for it?? look at http://www.smart-home-automation.ch i do not konw how does it works with the images. Can you help me out??
Your site appears to be completely blank with the exception of some menu items. Some tutorials are available here.. http://www.joomla51.com/tutorials , however if you could detail for us what you wish to achieve we will help you out as best we can.
Thanks for your request. I tray to get the J51_SlideshowModule working in the page. It works not around. 1,2,3,1,2,3 and so on (i have 3 Picture) and the navigation also not work¨.
Under Create your own stunning, clean and professional website you see on the demo Site the picture on the page an if mouse over the picture goes away and som text show up.
the Name of this Modul is??? i can not finde it in the zip file :dry:
Would you have a URL to an example of your slideshow issue?
The screenshot shows the GridGallery module which is included with your download. The install file for this extension can be found in the same folder as your template (mod_j51gridgallry.zip).
you find the Problem on http://www.smart-home-automation.ch
One thing i found out. The Name of the file must be short. if you habe somthing linke: smart-home-automation-Aussenansicht-Lichtszene.jpg does not work. But for google & Co is bad image1.jpg and image2.jpg.
The fIlename size of your images should not effect your slideshow however please ensure that no spaces are used and that all file extensions are in lowercase ('myimage.jpg' not my 'image.JPG').
If this is the case may I suggest setting us up with temporary administration access to your Joomla installation and we will examine the issue further. Please paste a link to this post in your email for our reference.
can you send me your Email Adress??
Details can be sent to [email protected]
We have enabled jQuery within your slideshow modules parameters and it is now working correctly. By default jQuery is not loaded in Joomla 2.5
Thank You. Now all works perfekt!! Great
