1. simon_2013
  3. Wednesday, 28 January 2015
I bought the resonate template in 2013. Now, I'm using it for a client's site. The issue is that when I view it on a mobile device, the main menu seems to overlap the home page text. See attached screen shot. Can you help?
regards, Simon.
Hi Simon
Please ensure you have the latest version of the template installed. The latest download should be now available to you via your 'My Downloads'. This should resolve this issue for you. To update simply install via your Extensions Manager.
Thanks for your response Ciaran,
The updated template has solved the issue but it seems that my main menu disappears when view on mobile device. Please check http://www.somalifishingcompany.co.ke to verify this. I would really appreciate your advise on way forward. Also I do not want to have the footer menu as main menu since I'm creating a link to our company's website at the same position.
Kind regards,
Simon.
Hi Simon
Your site appears to be offline. Access details can be forwarded to [email protected]. Please paste a link to this post in your email for our reference.
