1. erikoraka
  4. Thursday, 09 May 2024
Can you please check and advise as in the following url the Header Gradient color does not seem to work
https://www.eriswebstudio.gr/joomla4/
Thank you in advance.
Best regards,
Eri
Hi Eri
There appears to be a call to undefined error on your site and it is currently not loading.
My host provider tells me that the error 0 - Call to undefined method Joomla\CMS\Factory::getContainer() is not a server error. Do you have any idea if this is a template error? I have installed Madison for Joomla 4.Can you please check?
Let me also tell you that I have installed J51 ImageHover Gallery Module. Is it compatible with Joomla 4? Does this cause the problem?
And I do not even have access to administrator, I get a white page with Error written on the left top corner.
Yesterday the site was working fine. Something happened today without changing anything and I get this error.
Looking forward to your reply.
Thanks again,
Eri
Hi Eri
We dont use the getContainer method in our templates so I do not believe so. Try disabling all modules and 3rd party plugins and see if the issue persists?
I redeveloped the site under a different domain name and everything it seems ok now.
Can you please check now the problem with the gradient color in the following url
https://www.experiencerealgreece.gr/eri/en/
Thank you again.
Eri
Can you please advise about the gradient not working in the following url?
Thank you again.
Eri
Can you please advise why the gradient color is not working in the following url regarding Madison template?
Thank you again,
Eri
Hi Eri
I have sent you the credentials via email.
Thanks again,
Eri
Kind reminder on my request above.
Best regards,
Eri
Thank you Eri
A new template update has been created and this update has been installed to your Joomla installation.
Thank you Ciaran!
