1. chrissi777
  3. Thursday, 02 May 2024
I updated 2 Projects from J3 to J4 and I have the same Problem on both.
The Frontend is not working. 500 - behavior::caption not found.
Its J 4.4.4 php 8.3 MySql 8.0 Backend looks good. I tried Cassiopaia Template for test - this works
I did the same routine than on the other projects - those both with London Template do not work.
Chris
Did you check whether the Backward Compatibility Plugin is enabled?
Backward Compatibility Plugin: is this not a feature from J5?
And no. I updated 40 other sites and I only have that issue with the London template.
Hi Chris
