1. joan
  4. Monday, 23 April 2018
Made a login module in the menu, Kinvara template, works well.
One sort of problem, after filling in your name and "remember password" the next time you login the box disappears when providing "Login Name".
You have to mouse over again to make it visible.
Any suggestions?
  1. http://185.104.29.80/~droogdok2018/
Hi Joan
Hi Joan
This is proving to be a little difficult as the warning is rendered by your browser and not your website which is why the dropdown disappears. It assumes you are no longer hovering over the menu. Do you plan on securing your site (SSL cert)? This will remove the warning and therefore resolve this issue.
Hi Ciarán,
In a earlier site I made the same setup ( https://www.downtownabbey.nl ). Here is the SSL already present but the behavior of the module seems the same?
Joan
