1. salinger
  4. Tuesday, 28 March 2023
I have troubles with Emani template and web fonts local use. The fun fact , I did exactly the same on two websites with the same template EMANI, but it only worked on one :(
Here it is perfect (see headers) http://bewusst-ich.co.at/index.php
here not (headers still ARIAL): http://www.vintagequeen.eu
I have copied the custom.css and the fonts from one site to the other, and put it in the same place , NO CHANGES TO THE FILE AT ALL!
here is the custom.css
I made no changes to the fonts.php file (on both websites).
there are no relevant changes in the template styles (custom.css).
do you have an idea how this can even be possible ??? any solution?
thank you so much!
Marion
Hi Marion
Looking at the network of your site, you appear to be getting 404 not found errors for each of your font files. Try using the full URL to your font location in your CSS.
Thanks Ciaran, the full path did work! finally :D :-))):D :D :D
regards, Marion
Hi Marion
Is the issue resolved if you copy your CSS directly to your template style settings Custom CSS field?
Hi Ciaran, no I have tried this as well. It worked fine with a separate CSS file on the other site so I did exactly the same way no minimize errors on my side ;)
