1. Oliver
  4. Monday, 11 May 2015
Hello Joomla51 team,
hello Ciaran,
I have a little issue with the carousel module.
Scenario:
Position: sidecol_b
Nr of columns: 2
Columns per slide: 1
Url: http://winkler.oliver-lorch.de/index.php/gardinen.html
As you can see (pls check attachment or website), the second column always appears after the change.
What have I done wrong? Or is this kind of using the carousel not possible?
Thanks in advance
Oliver
Hi Oliver
To amend try adding the following to the Custom CSS field of your templates parameters....
.sidecol_block .owl-carousel {
overflow: hidden !important;
Thanks Ciaran, it works fine :)
