1. Oliver
  4. Tuesday, 31 October 2023
I have a little issue on the Chloe template.
My customer uses a Mac for work and on his Mac he has the problem, that the menu chrashes after scrolling down and then scrolling up again.
The horizontal menu changes to vertical and one has to reload the page to correct this. Pls see screenshot.
I fact I do not own a Mac pc I have the problem that I could not work on this issue.
But maybe you have an idea and maybe a little fix for this?
Thanks in advance
Oliver
  1. https://steveart.de/
Hi Oliver
Strangely we are unable to replicate this issue. As a shot in the dark, try adding the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
.hornav,
.is-sticky .hornav {
width: 100%;
thanks a lot for trying. I really appreciate this :D
Sorry to say, that it does not work.
Its not a big problem, my custer says, if he is the only one who has this problem, than its fine for him ^^
But if you have any other suggestion it would be awesome :)
Kind regards
Oliver
