1. Marina
  3. Friday, 20 October 2017
Links in the mobile version of the site do not work (template J51 - Ashley)
What to do?
Hello!
I explained the problem incorrectly.
The menu links on the mobile version of the site are working.
Do not work all other links - in articles, read more... and etc.
The J51 template is Ashley. Website - http://www.celiac.ch-aj.com/
Sincerely, Marina
Hi Marina
We appear to be unable to replicate this issue. Is the issue present on all menu items? On what device are you have the issue?
Hello!
There are no problems with the menu. The top menu works on all devices.
The problem with links in the texts. Links in texts, references "read more" and others do not work.
The problem is present on smartphones.
Sincerely, Marina
Hello!
What should I do with the problem of browsing the site on mobile devices?
The buttons "read more" and the links in the articles do not work.
Sincerely, Marina
Hey!
I will turn on Google Auto Ads for one day.
So you can see the problem.
If this option is disabled in Google Ads, the mobile version of the site works fine.
https://www.celiac.ch-aj.com/
  1. https://www.celiac.ch-aj.com/
Is this issue present if you enable the default Joomla template (Protostar)? Are you using a plugin or a custom module to add Google Ads to your page?
