1. erikoraka
  4. Thursday, 25 September 2014
Hi Ciarán,
I have installed the Code7 Responsive Accordion Module. When i use it in position contentbottom-a the font is different from the one I use in the articles body (ie Garamond).
How do I change the modules font in order to be the same with the one I use in the articles body?
Thank you in advance!
Eri
Hi Eri
Would you have a URL to an example of your module?
Here's the link:
http://www.megarevma.gr/new/index.php?option=com_content&view=article&id=6&Itemid=110
You will notice that the font of the accordion's title in the bottom of the article is different from the body text of the article..
Try adding the following to the Custom CSS field of your templates parameters..
.fancypantsaccordionholder ul li > a {
font-family: Garamond, sans-serif;
Thank you!
Now it seems ok!
The same problem happens also with the accordion in the second tab, in the bottom of the following page..
http://www.megarevma.gr/new/index.php?option=com_content&;view=article&id=19&Itemid=116
Try also adding the following to your Custom CSS field...
h4 {
font-family: Georgia,serif;
