Message
OSM_INVALID_SUBSCRIPTION_PLAN
  1. erikoraka
  4. Wednesday, 17 September 2014
Hi, how can I transform the capital letters of the Hornav menu to small?
Thank you in advance,
Eri
Hi Eri
Could you try adding the following to the Custom CSS field of your templates parameters..
#hornav > ul > li > a {
text-transform: none;
Ciarán thank you for your reply.
I added the code to the file /css/template_rtl.css as follows
/* Menus */
#hornav li, #hornav li li {
float: right;
#hornav ul li a {
But there was no change...
Could you advice on this?
Thnx
Hi Eri
The suggested CSS can be added to the Custom CSS field of yoru templates parameters. From your Joomla administration navigate to Extensions -> Template Manager -> j51_Lifestyle -> Custom CSS.
It works fine!
Thank you :)
Hi Ciarán,
How can I set the text transform=none from the whole template?
Thank you once more!
Eri
Hi Eri
You could try adding something like the following to the Custom CSS field of your templates parameters...
body {text-transform: none !important;}
